1 - 19 of 19 Posts
255's will fit with room to spare, and 275's should fit without too much trouble. But that's assuming the wheel size and offset are optimal. I actually have a pic of a 240 with 315's on the back on stock fenders, but I have no idea if the guy had any rubbing problems at all.
Shit, I misread and thought he was asking about tires.
Many people run 10 inch wide wheels in the back on S14's. I'm not sure if the same can be said for S13's. I think their wheel wells are a little smaller.
The question says "with rolling the fenders"....
OK, I just realized I have failed at this thread.
If you don't mind pulling your fenders, you can fit some 275+ back there no problem. The key is offset, offset, offset.
i've got a 17x9.5 with a 275 rear tire slight camber (not sure exactly how much) all i had to do was knock the inner lip of the rear fenders flush close but no rubbing
GOT HEEM
pkease tell me you don't have rolled stock fenders under your rivit on over flares...
DONT DO A MOTOR SWAP!!!
I'm running some 275's out back with no roll and no rub:loco:
Honda Rapist
i'd like to see the guy's setup w/ the 315s out back
1 - 19 of 19 Posts
