Hey Billy, I was wanting to see when/if I could bring the STi by and have you check it out. I didn't gain much knowledge from the other checkup I had the other day. I am having some new tires put on Monday, and I will be off from Monday-Thursday, so I could possibly come up there then if you are available. Anytime after that and I wont' be available during the week until sometime after February.
These are the symptoms of the problems:
1.
When driving, there is a pronounced "whine" or "hum" or "waaaaaa" sound when over about 10mph. It changes tone with the speed of the vehicle, not the engine speed. It occurs when the wheel is slightly held to the right, or when turning to the right at speed. When the wheel is turned left, the noise goes away. Over the past few days, the noise has slightly begun to be faintly heard when the wheel is held straight. They checked the wheel bearings, and no significant noise was heard from those. I know I have at least one axle boot torn. The noise seems to be coming from the driver's front, and the known axle boot tear is on the passenger side, if I remember correctly. The noise and occurance is consitant and is significant. I would really like to diagnose this issue and possibly get it repaired.
2.
Slight oil leak located on the driver's side of the engine somewhere. It leaves a puddle the size of a couple thumbnails each day.
3.
When driving and adjusting the DCCD from auto to manual and changing the torque ratio, popping/clicking noise occurs from the center differential. Is this something that will require a center differntial replacement? I plan to replace the tranny fluid and rear differential fluid soon, hoping to minimize this noise, but it will probably not help much.
I would really like a thorough check and find any other small or major issues that the car might have. I would like to get these things taken care of before I start feeling too confident about driving long distances or upgrading the performance.
My main concern is the humming/roaring noise from the front, and the clicking from the differential. I would really appreciate any insight at this point, and hopefully you will be able to get me in to get this thing checked out soon. I want the car to be fun to drive, not afraid I'm going to break it.
Thanks a ton.
1.
2.
3.
Thanks a ton.
