1 - 14 of 14 Posts
Talon o' lantern
i recently bought a bone stock 91 b13.
i plan to add a short ram intake in the very near future
this thread has prolly been posted b4,
my newbness shines thru! haha,
for my current application which would be the best:
- spark plug (type and brand)
- exhaust (2.25in or 2.5in)
thats all thats on my mind right now
im sure i will post other random shit.
i did search and found a lot of info.
i just wanna hear some of your biased and unbiased opinions.
boosted family car ;)
NGK FTW ive always ran NGK plugs i refuse to run anything else
Step 1: Don't waste your money on the intake.
Step 2: Save your money and get an SR20DET for around $1300 and swap it.
Step 3: Roll bitches up.
its alive, but needs 2b tuned
only use NGK plugs! go with 2.5 exhaust.
you should check out www.sr20forum.com , they will have any info you need.
sr20's are fun in de form- do a 3 inch intake, 2.5 inch exhaust, ngk plugs
Talon o' lantern
drifter_240sx
i used them in my honda and never had any problems,
just wasnt sure about the sr20,
thanx
9825rs
i am a member of that forum as of sunday,
so i havent had much time to invest
just wanted some input from my fellow 502ers
thanx man
92EclipseFWD
my thoughts exactly! im not wanting to make it a det,
i have a perfectly good de and i want to make this thing turn!
thanx a lot for all the responses,
any other FYI's you may have,
send'em my way.
i added prothane mounts to mine, removed the egr, and put an intake on it and advanced the timing and the car flat out screams for a relatively stock car.... no the mounts/egr added any power- but the mounts truly make it alot more fun to drive...and the egr causes all kinds of problems when they get clogged- im in the process of doing a jdm swap....
NGK's are what I always use,can't go wrong.Bump the timing to 17-19 degrees,and drive it like you stole it.Lots of things you can do with one,and they're all fun.Ask me,I've had a 93,and currently have a 96 & 97 Se-R.Bulletproof.
just do the basics and have fun with it. ive had 2 93's and both were great. 1 was for autocrossing and did pretty good in it. i now have a 92 with a gti-r swap, mega fun, and a 98 i use for dd.
Talon o' lantern
Discussion Starter · #12 · (Edited)
92EclipseFWD
are the stock mounts prone to fail under lead footing?
or do the aftermarket mounts just add security and fun?
is there a lot involved in removing the egr, im very interested in this. link?
im down for eliminating anything! ha.
Bucky13
i read about advancing the timing to 15 degrees,
i also read 17 degrees was living on the edge?!
true/false/opinion?!?!?!
jingjing
i dont plan on using this car for autoX,
but i would like it to turn and do it well...
to be honest the entire suspension has seen better days
and the struts are SHOT
so something needs to be done, and soon...
thanx for all your input
long live niSwaN
Talon o' lantern
Discussion Starter · #13 ·
what about fluids.
in the glove box i found a log book of...
oil changes from the original owner,
every 2k-3k miles from
mile #2,009 up to 118,335.5
thank you sir!
after that guy, matt bought it
and i bought it from him
he changed the oil maybe a half dozen times
within the last 6.5 years and 40k miles
someone advised me to release a quart of oil and put in ATF
and the detergents in it will clean the engine.
anyone know if this works?
im very, very hesitant...
i wanted to use mobile1 synthetic,
would that hurt the engine?
considering its always used regular oil
or help the engine?
is it worth the money?
any lucas products recommended,
engine? trans? other?
thanx for your time
sorry for the long post...
Cares not about REP!
what about fluids.
thank you sir!
or help the engine?
thanx for your time
did not read most of this but save yourself a motor do not use any product lucas makes everyone of them is harmful to the car.. except octane booster just because it is pretty general
1 - 14 of 14 Posts
