1 - 20 of 47 Posts
Music Modder\SPL-Lab Distro
I am about to do a big project in my car that requires me to sell all of my existing AQ subs.
I have-
2 AQ HDC3 12" Dual 2 ohm Copper Coil subs.
1 AQ HD3 15" Dual 2 ohm 15" Original sub
1 AQ HD3 15" Dual 2 ohm 15" Revised Original sub
Pricing -
HDC312s - $215 per or $400 for both
HD315s - $250 per or $450 for both
Handling capability-
1000-1500w for SQ music.
1501-2500w for SQL music.
2501-3,500w for short term LouD music.
3,501w+ for Competition burst only.
Box requirements for best performance-
12s - 2.5 cubes per sub\5.0 cubes for both tuned to 38hz
15s- 4.5 cubes per sub\9.0 cubes for both tuned to 40hz
Capable of dropping to 30hz with both box types due to long excursion capabilities. Xmech(peak to peak excursion mechanical) - 3.0" for 15s, just over 3.0" for the 12s.
Typical mainstream subwoofers are lucky to see 2.0"
All subs work of course, no problems with any of them.
I'm trying to sell all 4 so i can go with 2 brand new 18s in a wall in my Scion tC... the loudest daily driven tC around...
Please buy! There is a big project coming this summer and all this has to go.
In about a month, ALL of my amps and batteries will be for sale!
2 AQ2200ds = 4,400w of power.
2 XS D5100s = 60aH per, good for up to 3,000w amp per battery.
1 XS D3100 = 117aH, good for as much as a 5,000w amp
These new products will be attempted to be sold within the next 3-4 weeks.
You're selling you d3100? Man, only if I waited.
The prices just dropped $5 if being shipped.
Someone told me i was selling these too high but what some people must realize is that AQ charges shipping on their subs and these prices are far cheaper.
HDC312-
1 sub- $255 shipped
2 subs-$490 shipped
HD315-
1 sub - $290 shipped
2 subs-$565 shipped
Are you local? in the Louisville, KY area?
HDC312-
1 sub -$215
2 subs-$400
HD315-
1 sub -$250
2 subs-$450
New Equipment for sale!!!
2 AQ2200Ds
Specifications
Model AQ2200D
Digital Monoblock 1 ohm stable
Input Sensitivity 0.2v-8v
Variable Low Pass Filter 20Hz-200Hz @ 24dB/Oct
Subsonic Filter 10Hz-50Hz @ 24dB/Oct
Output Master / Input Slave, 2 amps linkable connection
Remote Level Control
Clipping Display Led
Signal to Noise Ratio 90dB
External Fuse Rating 200 Amps, 400 Amps Linked
Tested Voltage 14.4V
4 ohm power @ 12V @ 1% THD 500x 1
1 ohm power 2200 x 1
1 ohm Power @ 16V 2500 x 1
2 ohm Linked Power @ 14.4V @ 1% THD 4400 x 1
Dimensions 17.71"(L)x9.27"(W)x2.35"(H)
They go for $389 per amp.
Selling price is as follows-
Local prices in the Louisville, KY area-
1 AQ2200D - $325
2 AQ2200Ds- $615
Shipping Prices -
1 AQ2200D - $345
2 AQ2200Ds- $650
XS Powermaster Batteries-
I have 2 D5100s and 1 D3100
D5100-
60aH
1600CA amps
Good for up to a 3KW amp
They go for around ~$155
D3100-
117aH
3200CA amps
Good for up to 5KW amp
They go for around ~$300
I am NOT shipping these batteries, pick up only. It would cost too much and not be beneficial for anyone if i had to ship any of them.
D5100-
1 Batt - $120
2 Batts-$230
D3100-
1 Batt - $235
Hey, if these are shipped then go post up on CACO, CA, and ROE. DO IT!
OMG, then buy it, lol
Pics of what i'm sellin-
My 2 12" HDC3 12s -
That's the only pic i have because they are still installed and will be removed once i receive payment.
2 D5100s and 1 D3100 Powermaster XS batteries-
Here are both of my AQ2200ds-
This picture below shows how install care was taken to ensure vibration control-
Luxury Liner Pro under bottom amp and multi-layered rubber washers on top amp.
Amp's properly spaced apart to allow heat dissipation.
Luxury Liner Pro was precisely cut to allow airflow from all 3 vents underneath the AQ amp. These amps have not gotten hot at all.
NONE of these amps have seen a load below 2.3 ohms actual! Due to high impedance rise, this is why.
I'll try and get some pics of the 15s later on this week.
resize the pics sean. its too big.
you should get pics of the 3500 amp coming in. ;)
I thought people liked detail?
Discussion Starter · #14 ·
New price drop on the 15s-
for 1- $225 LOCAL PICKUP
for both- $420 LOCAL PICKUP
shipped prices remain the same as before.
New price drop on the AQ2200Ds-
For 1- $300 LOCAL PICKUP
For both- $575 LOCAL PICKUP
Addition-
If anyone buys any or both of the amps, i will offer to personally tune the amp for your setup AND, if wanted, help build your next setup using a custom test box i have to determine best box for your ride using this and a meter with spreadsheets for FREE.
You must be in the local area because i'm not gonna be willing to drive cross country, hehe.
Discussion Starter · #15 ·
Come on people.
I just got back from the local Stereo Competition and ...
I posted a 148.0 @42hz running 2,300w of metered power!
This is off of the 2 HDC312s i'm selling.
So now u know what they are capable of... buy them please! hehe.
PS.. I broke a 147.0 at 34hz too :) And my box is over 1 cuft smaller than required so potential to be louder is 100% there.
Buy these subs...
i want your 15s soooo bad. but im broke.... are they aluminum coils or copper? can you post pics?
Discussion Starter · #17 ·
They are the original HD3s made in USA only. These were the ones that went for OVER $400 per sub before they started outsourcing to Korea.
This was back when you didn't have the choice between copper or aluminum so i can answer that question.
I can post pics maybe tomorrow?
k. ill check tomorrow. how much play time have these seen? quite a bit i will assume.
Discussion Starter · #19 ·
ha, u gonna love my answer if you think quite a bit.
I bought the first one back in 2004 and ran it off of a 1,500w amp for about 9 months. then they revised the line so i bought the new one. I didn't have room to run them both so i just did a direct swap and quit using the first one now for 5 yrs! It's still sittin here.
I used the revised one for about 4 months then sold the car and now it's been sittin here for about 4.5yrs.
Yes they both work, i dropped one fo the 2 in a temporary sealed box about 2 yrs later and ran it off of the same 1,500w amp for about 6 more months then took it back out and they been sittin ever since.
I've been tryin to sell em now for over 2 yrs.
So if I were to buy both of your 15s, would I have a hard time finding two more, or are they the same as copper coil HDC3s.
1 - 20 of 47 Posts
