1 - 1 of 1 Posts
That funky monkey
Eibach Pro-Kit is the perfect answer for most frequently-driven street cars. It's our legendary spring system that dramatically improves both a vehicle's performance and appearance.
Pro-Kit lowers your Cube's center of gravity, reducing squat during acceleration, body roll in corners and excessive nose-dive under braking. When combined with today's high-performance wheels and tires, the Eibach Pro-Kit is the finishing touch to a winning recipe for performance.
Pro-Kit also reduces excessive fender-well clearance, making your car look just as hot as it performs.
Pro-Kit #6395.140 Features:
* High Performance Handling and Aggressive Good Looks
* Lower Center of Gravity — Lowers Cube 1.3" Front and 1.0" Rear
* Stop Quicker, Corner Faster and get Better MPG
* Progressive Spring Design for Excellent Ride Quality
* Million Mile Warranty
Every Eibach Pro-Kit is designed and tested by our suspension engineers and performance driving professionals, to deliver aggressive good looks and high performance handling, without ever compromising safety or ride quality. By using our proprietary, progressive spring design, Pro-Kit provides the ultimate balance to take your passion for driving to a whole new level.
TECHNICAL INFORMATION FRONT:
* OE rate: 26 N/mm (146 lbs/in)
* PK rate: Progressive 25-33 N/mm (143-190 lbs/in)
* Tubing: Yes
* Bump-stop: New Eibach Springs bump-stop
* Dust-boot: New Eibach Springs dust-boot
* Damper: OE
* OE wheel center to fender: 389 mm (15.3 in)
* PK wheel center to fender: 356 mm (14.0 in)
Note: Pro-Kit can be aligned to OE alignment specifications. Approximate installation time: 1.5 hr
TECHNICAL INFORMATION REAR:
* OE rate: 42 N/mm (241 lbs/in)
* PK rate: Progressive 26-55 N/mm (148-313 lbs/in)
* Tubing: Yes
* Bump-stop: OE
* Damper: OE
* OE wheel center to fender: 381 mm (15.0 in)
* PK wheel center to fender: 355 mm (14.0 in)
Note: Pro-Kit will result in rear toe out of specification. Alignment kit is recommended. Alignment kit is not available at time of this release. Approximate installation time: 1.5 hr
Part#: 6395.140
Make: 2010 NISSAN
Model: Cube, Z12 1.8L 4 Cyl.
Lowering Height: Front 1.3" and Rear 1.0"
MSRP: $329.00
STREET HEAT MOTORSPORTS PRICE: $210 SHIPPED!
1 - 1 of 1 Posts
