1 - 7 of 7 Posts
WARNING BIG PICTURES SORRY!
Well here it is the easy way to swap Del Sol seats into an EF Civic Si I search many forms looking for pictures and help and there isn't much out there other then seat pan swaps and lots of seat recovering work. SO I took pictures and thought Id help others out.
I was tired of this... Ill miss the SI seats but the del sols look good and are much lighter
I started on the passenger side took the seat out to see how close the rails are since I could find any pictures of the two next to each other. So here are a few pictures to give a general idea of what the differences are.
[/URL][/IMG]
the same rail one just isn't bent like the other MAGIC!
The inside ones are the ones needed to be changes and added to, The del sol seat is a more narrow then the SI so it has clearance but a little more room by the shifter and e-brake.
[/URL][/IMG]
Del Sol outer ( I drew in how the rail brace would look like before I took it off sorry I forgot to take a picture before I took the rivets out)
[/URL][/IMG]
SI outer
Now a few thing you need Vice Grips Hammer Nuts and Bolts (size in pic) washers to fit bolt, Drill and Bits 3/8 and 1/4 is what I used. Leather glove for hot metal.
[/URL][/IMG]
First things First Lets Remove the Del Sol front inside rail brace, take the drill 1/4 bit and drill the rivets out. Use the leather glove the metal gets hot and the rivets some out smoking.
[/URL][/IMG]
this is what the Del sol looks like before the swap the hole is pointed in.
[/URL][/IMG]
this is the after you swap the brace the other direction.
After you removed the brace from both passenger and driver side then switch the braces to the opposite side! Magic! With the switch it brings the seat brace hole real close to the stock hole, crazy how that worked out. (With that out its means you need to do both seats or find the inner rail off the opposite side you wanting to do) You most likely will be doing the driver side so you need an inner rail off the passenger side seat!
Now take the Bolts from the picture.......... they fit just right and they are a nice length.
This with the brace switched over and bolted in (Im going to weld it in the near future but its holding fine)
Now lets bend the other Tab on the other rail. Take the Vice Grips and use some muscle.
[/URL][/IMG]
[/URL][/IMG]
After bending it as far as the vices will do then you will need to take a hammer and flatten it out more closer to the rails and rivets us a piece of wood or support on the other end and have some one hold the seat rail lock open so you don't bend it I didn't on the first on and had to fix that issue so heads up on that.
[/URL][/IMG]
See the u shape piece of metal hammer it and bend it from the edge of that it should look like this
Remember the other drill bit you are going to have to wide the holes on the two braces you modified
first the rounded flipped one widen it toward the inside of the car and the other new bent brace move the hole down in the back
[/URL][/IMG]
[/URL][/IMG]
On the front stock brace un modified I put a couple of washer behind it to make sure the back was pull in tight to get the bolt in all the way.
[/URL][/IMG]
Now the back on is the only one you will need to cut some metal to weld in or bolt in for the back corner Im making one out of steel and going to weld it on to bolt it back the back but I have nothing on it at the moment.
[/URL][/IMG]
Well there you have it! Its easy took only a 30 minuets for both seats it was simple and cheap. Just make arrangements to get that back corner brace made. But here is the final product. Just the passenger in the pic.
[/URL][/IMG]
If you got questions please let me know ill try to help.
I was going to do this swap in my wagon but the brackets were way to off for me to even attempt this. I've decided to go with da seats which is a much easier swap. Now I just need to find me a set with rails.
yeah its not to bad find some rails and go for it. much easier then pan swapping and all that crap
There's a write up to put da seats in a wagon and its really easy. Shaving a few tabs and swapping the inner rails out. Drilling mounting holes and bolt them up. The hardest part is finding a set out of a 90-92 with rails and auto belts.
Stunting is a habit
I did a pan swap on a ef a few years ago. It was not so bad but this looks way easier.
Discussion Starter · #6 ·
thanks it was real easy and worked nice....
I found an easy way to get the rear inside bolt hole to line up just to cut and bent the piece down and drill a hole to line up with it. then I welded up all the brackets to make sure they wont move.
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
SI outer
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
[/URL][/IMG]
cant see the pictures
1 - 7 of 7 Posts
