1 - 2 of 2 Posts
For real
I wanted to get some input about a new clutch for my 7 I am leading to ACT or spec. Just need to make up my mind when iget my tax check back. Also I have already replaced the slave and master I should go ahead and get the Steal line to replace the rubber 1 is there anything else I might wanna get or replace?
The Rotary Masochist
I've had good luck with both. Make sure you break it in according to the instructions. If you replace the slave, master, and line there isn't much left to replace. Do the pilot bearing, seal, and throwout bearing while you're in there.
1 - 2 of 2 Posts
