Chime in VW vets - 502StreetScene
Go Back   502StreetScene > Automotive & Motorsports > Specific Automotive Tech & DIY > Volkswagen/Audi
Thanks Thanks:  0
Old 01-13-2013, 11:22 AM   #1
kydreamsllc
kydreamsllc's Avatar
kydreamsllc kydreamsllc kydreamsllc kydreamsllc kydreamsllc kydreamsllc kydreamsllc kydreamsllc kydreamsllc kydreamsllc kydreamsllc
Chime in VW vets
Quick story:
2000 Jetta GLS 2.0 Automatic 195K miles
Car worked fine all week. Friday when driving home from work car lost power quickly I pulled to the shoulder it died. After steam cleared I discovered that my water outlet flange was severely cracked. I was towed home. I replaced the water outlet flange, and the thermostat. Car will turn over weakly but wont start. Sometimes it turns strong but still wont start. When it turns there are not grinding or bad noises.
Have checked battery, scanned it with obdII sensor with no codes, new ignition coil a few months ago. Timing belt is intact but don't know if its in time. Fuel pump engages so its getting fuel. No water or coolant in oil.
I'm in Frankfort, text or call if you have any ideals. Thanks
Maurice 502-320-4637
kydreamsllc is offline   Reply With Quote
Old 01-13-2013, 11:34 AM   #2
tomaconda
4 out of 5 women agree
tomaconda's Avatar
tomaconda tomaconda tomaconda tomaconda tomaconda tomaconda tomaconda tomaconda tomaconda tomaconda tomaconda
I am guessing head gasket/internal damage?
tomaconda is offline   Reply With Quote
Old 01-13-2013, 02:01 PM   #3
pinky
I love my jessipooh.
pinky's Avatar
pinky pinky pinky pinky pinky pinky pinky pinky pinky pinky pinky
Send a message via AIM to pinky
Did you noticed the temp gauge? You might have blown the headgasket or fucked the head or what not. do a compression test/leak down test and start from there.
03 turbo svt fuckus - 7psi and grippy tires
95 bmw 325i - 328 block, 325i intake, cam, header and tune 202rwhp - looking for 5speed swap and s50 cams
2.3t dunebuggy - hx35 @15psi, 42#injectors,la3 Ecuador tuned with tweecers, and much more.. less then 1700 with driver
pinky is offline   Reply With Quote
Old 01-14-2013, 12:09 AM   #4
kydreamsllc
Temp gauge was at max
Old 01-14-2013, 12:11 AM   #5
pinky
pinky's Avatar
Ouch
Old 01-17-2013, 03:57 PM   #6
BennettVW
On-ramp enthusiast
BennettVW's Avatar
BennettVW BennettVW BennettVW BennettVW BennettVW BennettVW BennettVW BennettVW BennettVW BennettVW BennettVW
Send a message via AIM to BennettVW
Try a compression test. That will give you the best quickest answer whether its ruined or not. How long did you drive it overheating?
Ive been up to my eyes in VWs for almost 10 years now. Shoot me a PM whenever you get those compression readings.
BennettVW is offline   Reply With Quote
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
