Anybody need a nice LED underhood light? - 502StreetScene
Go Back   502StreetScene > Automotive & Motorsports > On Topic
Old 03-16-2010, 08:47 AM   #1
19psi
Gator don't play no shit!
19psi's Avatar
19psi 19psi 19psi 19psi 19psi 19psi 19psi 19psi 19psi 19psi 19psi
NAPA has them on sale for $59.99.
CORDLESS 128-LED UNDER-HOOD WORK LIGHT Super-bright hands-free illumination makes under-hood repairs easier than ever!33" long 128-LED light head illuminates the entire engine compartment Rugged extruded aluminum hood mount telescopes from 50" to 80" to fit most hoods Spring-loaded telescoping arms grip hood-work light stays where you want it without slipping Powerful nickel-hydride batteries provide over three hours of continuous illumination, can be recharged over 500 times
Lightstorm™ Thunderhead™ Worklight features a high-impact polycarbonate lens (protects LED bulbs) and soft-coated heavy-duty end hooks (prevent damage or scratching of vehicle's finish). 1-1/2" diameter tube incorporates 128 LEDs with 100,000-hour bulb life. Brilliant light output is 1790 lumens (the incandescent equivalent of 100 watts). Includes battery pack (six 1.2 volt, 2.0 amp/hour MiMH cells) and two adapters (one AC, one DC).
regular price anywhere is over $100.
Chevrolet 2500 4x4, 6.6L Duramax, 5" exhaust, EFI Live, Banks Speedbrake, 20x10 AE 507s, 33x12.5 Federal Couragia M/Ts, Raptor lift pump, OE HID retrofit, Bilstein 5100s, Hard Notched Customs front bumper, 12,500lb winch, ATS rear Diff cover
Dyno'd at Dynosty: 402hp/734lb.ft.
Kawasaki ZX12R, Not stretched or lowered because I like going around corners at high rates of speed.
95 toyota truck 4x4, dana60 front/Elocker, 14B rear/Detroit, twin transfer cases, propane, 42" IROK's on beadlocks
19psi is offline   Reply With Quote
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
