Who turns rotors? - 502StreetScene
Go Back   502StreetScene > Automotive & Motorsports > On Topic
Old 03-15-2010, 07:47 PM   #1
TRAVR6
TRAVR6's Avatar
TRAVR6 TRAVR6 TRAVR6 TRAVR6 TRAVR6 TRAVR6 TRAVR6 TRAVR6 TRAVR6 TRAVR6 TRAVR6
Who turns rotors?
I need to have my rotors turned and cannot find anyone to do them.
I know Autozone used to do it but they no longer will.
O'reilly? Napa?
Anyone?
I am located off of cane run rd. Is there anyone nearby that turns rotors?
TRAVR6 is offline   Reply With Quote
Old 03-15-2010, 07:57 PM   #2
LloydXmas
I'm thinking Arby's
LloydXmas's Avatar
LloydXmas LloydXmas LloydXmas LloydXmas LloydXmas LloydXmas LloydXmas LloydXmas LloydXmas LloydXmas LloydXmas
Send a message via AIM to LloydXmas
my shop I work for can do them but will have to be on the car since we just got a new machine that trues them to the hub and the rest of the rotating mass. That way you get no vibrations. With turning them off thevbehicle it wont be true with the hub and may still get vibrations.
LloydXmas is offline   Reply With Quote
Old 03-15-2010, 08:09 PM   #3
91rangerturbo
2.3L Pawr
91rangerturbo's Avatar
91rangerturbo 91rangerturbo 91rangerturbo 91rangerturbo 91rangerturbo 91rangerturbo 91rangerturbo 91rangerturbo 91rangerturbo 91rangerturbo 91rangerturbo
We have a brake lathe and can do both rotors and hubs in my brothers garage. We do them for people on the side. But your in KY.
91rangerturbo is offline   Reply With Quote
Old 03-15-2010, 09:29 PM   #4
Drag_S14
Drag_S14 Drag_S14 Drag_S14 Drag_S14 Drag_S14 Drag_S14 Drag_S14 Drag_S14 Drag_S14 Drag_S14 Drag_S14
Send a message via AIM to Drag_S14
O'reilly? Napa?
Anyone?
Most NAPA's have the machines to do it, even if they don't have a machine shop.
Drag_S14 is offline   Reply With Quote
Old 03-15-2010, 09:34 PM   #5
Tskaggs747
Tskaggs747's Avatar
Tskaggs747 Tskaggs747 Tskaggs747 Tskaggs747 Tskaggs747 Tskaggs747 Tskaggs747 Tskaggs747 Tskaggs747 Tskaggs747 Tskaggs747
the oriley's across from honda on dixie is really good. i use them on all non hondas i need to turn rotors.
_____________________________________________
Street Stylez CC President Louisville Chapter
SIK n FRESH CREW
Tskaggs747 is offline   Reply With Quote
Old 03-15-2010, 09:57 PM   #6
Si_Guy_2209
Si_Guy_2209's Avatar
Si_Guy_2209 Si_Guy_2209 Si_Guy_2209 Si_Guy_2209 Si_Guy_2209 Si_Guy_2209 Si_Guy_2209 Si_Guy_2209 Si_Guy_2209 Si_Guy_2209 Si_Guy_2209
Any ken towery just take them in there and ask for the rotors to be turned
Si_Guy_2209 is offline   Reply With Quote
Old 03-16-2010, 07:50 AM   #7
19psi
Gator don't play no shit!
19psi's Avatar
19psi 19psi 19psi 19psi 19psi 19psi 19psi 19psi 19psi 19psi 19psi
NAPA still does it.
Chevrolet 2500 4x4, 6.6L Duramax, 5" exhaust, EFI Live, Banks Speedbrake, 20x10 AE 507s, 33x12.5 Federal Couragia M/Ts, Raptor lift pump, OE HID retrofit, Bilstein 5100s, Hard Notched Customs front bumper, 12,500lb winch, ATS rear Diff cover
Dyno'd at Dynosty: 402hp/734lb.ft.
Kawasaki ZX12R, Not stretched or lowered because I like going around corners at high rates of speed.
95 toyota truck 4x4, dana60 front/Elocker, 14B rear/Detroit, twin transfer cases, propane, 42" IROK's on beadlocks
19psi is offline   Reply With Quote
Old 03-16-2010, 07:51 AM   #8
19psi
19psi's Avatar
did you get a pro cut? who did you buy it from? I wish i knew you guys were looking for one, i could have hooked you up!
Old 03-18-2010, 04:04 PM   #9
TRAVR6
TRAVR6's Avatar
$35 each!!!!!!
O'reilly and napa will do i for $10
Thanks guys
Old 03-18-2010, 04:08 PM   #10
coupatroopa
coupatroopa's Avatar
coupatroopa coupatroopa coupatroopa coupatroopa coupatroopa coupatroopa coupatroopa coupatroopa coupatroopa coupatroopa coupatroopa
where at on Cane Run?
FIGHT MY BRUTE!
coupatroopa is offline   Reply With Quote
Old 03-18-2010, 04:48 PM   #11
flatl1n3
flatl1n3's Avatar
flatl1n3 flatl1n3 flatl1n3 flatl1n3 flatl1n3 flatl1n3 flatl1n3 flatl1n3 flatl1n3 flatl1n3 flatl1n3
NAPA on Lyndon has a machine shop and will do them during the week. You're SOL on weekends just about anywhere in the city tho.
D16b5/y8 12.5:1
Edelbrock Performer X intake
Bisimoto V2, 2.5" Magnaflow
SI LSD trans built by Bone
Hondata S300
flatl1n3 is offline   Reply With Quote
Old 03-20-2010, 12:35 PM   #12
Duster8
Duster8's Avatar
Duster8 Duster8 Duster8 Duster8 Duster8 Duster8 Duster8 Duster8 Duster8 Duster8 Duster8
Send a message via AIM to Duster8
discount auto in shepherdsville does them for $10 each i believe. open saturdays till at least 5 i think.
"If you find yourself in a fair fight, you didn't plan it properly."
-NRA member
Duster8 is offline   Reply With Quote
Old 03-20-2010, 01:27 PM   #13
Larry
Stunting is a habit
Larry's Avatar
Larry Larry Larry Larry Larry Larry Larry Larry Larry Larry Larry
Send a message via AIM to Larry
O'reilly's they did my cross drilled for like 15.00
1995 Acura Integra
I hate to advocate drugs, alcohol, violence, or insanity to anyone, but they've always worked for me.
Larry is offline   Reply With Quote
Old 03-20-2010, 01:50 PM   #14
Heather
Chill
Heather's Avatar
Heather Heather Heather Heather Heather Heather Heather Heather Heather Heather Heather
O'Reillys on Preston does them up until 6 or 8pm on Saturdays. $8 or $10 each I think.
Heather is offline   Reply With Quote
Copyright ©2000 - 2017, vBulletin Solutions, Inc.
